Hello all,
I have just purchased a 2000 suntracker regency 25 pontoon.
I have a Mercruiser 3.0L (S/N OL631822), I changed the plugs, wires, dist, and rotor. The manual, and everything I have read so far states my gap should be .035, but the flame arrestor states it should be .045 (cant be sure it is the original flame arrestor becasue the engine serial number is blank on the flame arrestor.
I set the gap to .045 but the engine is difficult to start, and has a rough idle until it is warmed up.
The old plugs seemed to be at .040.
Does anyone know what the gap should be for this engine?
Also, I have an electric choke, but the idle cam seems to lock the choke in full open. I loosen the idle screw, which frees up the choke cam, and then the choke moves freely as it should, and is in the almost closed position when cold. The electric part of the choke works fine, but when I move the throttle forward, the cam locks the choke wide open again and it is stuck there even when the engine cools back down. I have to loosen up the idle screw to free up the choke again, but as soon as I move the throttle forward, it locks it in wide open again.
Any help would be great!
Thanks!
Thanks!
