frostystorm
- May 22, 2023
- 21
I have a new 2019 long block with 150 compression across all the cylinders, and a brand new fuel filter in the pump.
It was built up from a blown up 2008 3.0 TKS, so long block replacement, toss all the old parts on the new engine, so the carb is definitely original, and it shows signs of being rebuilt at some point, and whoever did it stripped the screws holding the carb together out to a condition that is unrecognizable, so drill baby drill...
The Issue is if you hit like high 1700s to 1900 rpm the engine will either want to die, or it will drop back down to idling. I'll idle at 800-1100 all day fishing, or tow tubers all day at 3500-4500 without an issue. But if you put it right in the slot under load at 1750-1850 RPM, it'll just start being bitchy.
I am guessing this is carb related, although I have not put a timing light on it, but given it idles fine and runs fine all across the rev range, and is an HEI distributor, I can't imagine it is timing related.
My TKS module blew the 20amp fuse once this year, but given voltage it extends in and out to the range. Otherwise it hasn't given me any issues in that regard.
My conundrum, I cannot rebuild this carb, remember how I said it came from a 2008, well whomever rebuilt it prior stripped every screw on the carb beyond recognition, the only way it's coming apart is by drilling the screws out, and I know i'll **** that up.
I don't want to throw a new carb at it but probably will, so what should I check first? I am checking timing this weekend but I doubt it's off at idle, if its doing something it's behaving incorrectly at 1700-1800 rpm.
My guess is fuel related, and carb, because it idles and runs at full throttle fine. probably around when the idle circuit hands over to the main mix i would guess?
