JazzyontheHudson
- Apr 22, 2014
- 13
I have a 2000 Bayliner Capri 1952 with Mercruiser 3.0 and Alpha generation II. I just did cable adjustment and I am experiencing strange symptoms. When I try to start with shifter in the forward position, the boat acts if the ignition was cut off. When I move the handle into the center position, this goes away although I can start because the engine is cold and I cannot add throttle. I thought the cut off switch had to be the problem, even though I tested it before and it was working. I disconnected the switch but the boat is still doing the same thing. What could be the reason for this weird behavior?
The shift cable that goes to the outdrive (I think it is called lower cable although it is mounted on top of the shifting plate) is few months old and was adjusted to the required 6 inches. The other shift cable (which I think is called lower cable and is mounted below the other cable and behind shift assist) that goes to the control and the throttle cable are old. Could they be contributing to this situation? I am puzzled by what could be switching the ignition off besides the cut off switch. I am going to recheck the upper shift cable adjustment but could that be the problem.Please advise what I could try.
