davidhenson06
- Mar 6, 2016
- 6
I have a 99 mercruiser 3.0 that is running too rich. I blows lots of black smoke. Idles rough but accelerates fine and seems to run good at higher rpm. Any suggestions?
Those are only for idle mixture. Is your problem at idle or when normal running above idle?Tried adjusting the 2 screws on the side of the carburetor, started off at 1 1/4 turns out and then probably 3 more turns. Hasn't made any difference.
cleaned plugs with wire brush.
Since the Chevrolet division of GM doesn't make carbs, I would be very surprised if they did.Are marine carbs supposed to have Chevy bowties on them?
