Hello, I have a 2006, MerCruiser 3.0 that is running about 180 degrees F continuous. The motor also continues to diesel, or continues to want to run after I turn the ignition off. Additionally, after it does finally shutoff, I have to push the throttle up about half way to get the motor to start again. I have tried:
1. Carb Rebuild
2. Replaced the old thermostat with a new 160 degree F thermostat
3. Replaced the gas in the tank with fresh fuel
4. Replaced the water impeller in the outdrive.
5. Installed a Fuel/Water seperator
6. I've tried to let the boat idle after running it, but still get the run-on
Any help or ideas would be greatly appreciated.
Thanks
Ed
1. Carb Rebuild
Thanks
Ed
