Mercruiser 3.0 riser and manifold inspection - need replacement?
jeffsu350
I just purchased a 93 bayliner with a Mercruiser 3.0 I/O. I removed the riser to inspect for corrosion. I am unsure if this is a normal amount of corrosion and I should just put a new gasket on and move on or if I should replace the manifold and riser.
Thanks for your input!
alldodge
Howdy, looks like this should be in the Mercruiser section
Your camera is a bit out of focus being its so close, but from what I can see, might just take a flat file to the surfaces, then install a new carbon gasket
jeffsu350
I do see that I posted this. Mods please move if you can.
Thanks for the response. I had trouble getting good in focus pictures.
I don't want to neglect an issue and have a bigger problem but I also don't want to replace good parts.
Thanks again!
