I've got a 97 SeaPro 190 WA with a Mercruiser 3.0LX. The first year we had the boat (we've had it for about 4 years now), it ran like a champ. Every year since, I've had really bad luck with it. I've rebuilt the carburetor, replaced a lot of the ignition system components (plugs, wires, distributor), had the fuel cleaned by a fuel truck, replaced the fuel pump, and have recently verified the timing and choke settings. The main problem is symptomatic of fuel system problems in that my fuel filters get gunked up pretty quickly with small particles. Usually, if I swap filters out things improve for a trip or two..and then it's time for new filters. I've also installed an inline fuel filter/water separator.
Is there anything else that could be "off" that could make the engine more sensitive to a clogged filter?
From my last carburetor rebuild, I'm not 100% positive that the gasket sealing the venturi cluster is perfect. For some reason, the rebuild kit didn't have a new one this time and I tried to reuse the old one.
Thanks in advance for any advice you might have - it's been a frustrating few years here recently, as you can imagine!
