mercruiser 3.0 L how to secure the flywheel pulley that drives the alternator
  • what is a poll answer ?
    Votes: 0 0.0%
  • I have no clue what you look for.
    Votes: 0 0.0%
  • xxxxxxxxm
    Votes: 1 100.0%
  • Total voters
howem1
The pulley is loose and I wish to find out what is required to make it secure & stable.
GA_Boater
Welcome aboard with a poll that makes no sense.
B̶u̶t̶ ̶a̶r̶e̶ ̶y̶o̶u̶ ̶t̶a̶l̶k̶i̶n̶g̶ ̶a̶b̶o̶u̶t̶ ̶t̶h̶e̶ ̶l̶a̶r̶g̶e̶ ̶p̶u̶l̶l̶e̶y̶ ̶o̶n̶ ̶t̶h̶e̶ ̶c̶r̶a̶n̶k̶s̶h̶a̶f̶t̶?̶ ̶T̶h̶a̶t̶ ̶i̶s̶ ̶t̶h̶e̶ ̶h̶a̶r̶m̶o̶n̶i̶c̶ ̶b̶a̶l̶a̶n̶c̶e̶r̶.̶
̶I̶s̶ ̶t̶h̶e̶ ̶h̶a̶r̶m̶o̶n̶i̶c̶ ̶b̶a̶l̶a̶n̶c̶e̶r̶ ̶l̶o̶o̶s̶e̶ ̶o̶n̶ ̶t̶h̶e̶ ̶c̶r̶a̶n̶k̶s̶h̶a̶f̶t̶ ̶o̶r̶ ̶i̶s̶ ̶t̶h̶e̶ ̶p̶u̶l̶l̶e̶y̶ ̶l̶o̶o̶s̶e̶ ̶o̶n̶ ̶t̶h̶e̶ ̶h̶u̶b̶?̶
̶L̶o̶o̶s̶e̶ ̶o̶n̶ ̶t̶h̶e̶ ̶c̶r̶a̶n̶k̶s̶h̶a̶f̶t̶,̶ ̶t̶h̶e̶ ̶c̶e̶n̶t̶e̶r̶ ̶b̶o̶l̶t̶ ̶i̶n̶t̶o̶ ̶t̶h̶e̶ ̶c̶r̶a̶n̶k̶ ̶i̶s̶ ̶t̶i̶g̶h̶t̶e̶n̶e̶d̶.̶ ̶L̶o̶o̶s̶e̶ ̶o̶n̶ ̶t̶h̶e̶ ̶h̶u̶b̶ ̶m̶e̶a̶n̶s̶ ̶r̶e̶p̶l̶a̶c̶i̶n̶g̶ ̶t̶h̶e̶ ̶b̶a̶l̶a̶n̶c̶e̶r̶.̶
Never mind all that - took your motor to be a Mercruiser.
Starting over - What's the serial number of the motor?
GA_Boater
I think the pulley is keyed to the crankshaft and the flywheel holds it from moving.
Chris1956
Better if this is reposted in the MerCruiser section, as a simple question. Also clarify whether the water pump pulley is loose or the lower crankshaft pulley is loose.
howem1
The pulley is the lower one (not on the water pump). It says nothing about it in the MerCruiser Alpha One 3.0 L manual. The only thing in the manual is a picture on pg. 27 which shows a partial view.
If the pulley is keyed to the crank, do I have to remove the engine mount to get it in place?
Ayuh,.... Welcome Aboard,.... Yes, behind the mount are the bolts that hold the pulley to the balancer,...
