Re: MerCruiser 3.0 L coldstart problems
Oh and sorry about my inexperience but the anti-siphon valve is that connected to the fuel pump or the carburetor
Neither, it's on the gas tank. But the anti syphon, nor your fuel pump is the problem. If they were at fault it not only would be hard to start, it wouldn't keep running or run fine at higher rpm.
it's also normal to pump a carbed engine 1 or 2 times to start, and after setting for a few weeks may take an extra pump.
Here is a copy and paste from an owners manual on how to start a carbed engine. Then it should start easily again.
Starting And Stopping The Engine
NOTE: Only perform those functions applicable to your power package.
1. Check all items listed in Operation Chart.
2. Place the remote control handle in NEUTRAL.
CAUTION
Overheating from insufficient cooling water will cause engine and drive system
damage. Ensure that there is sufficient water always available at water inlet holes
during operation.
WARNING
Explosive gasoline fumes collect in the engine compartment. Avoid injury or
property damage, operate the bilge blower for at least five minutes prior to starting
the engine. If the boat is not equipped with a bilge blower, open the engine hatch
and leave it open while starting the engine.
3. Push THROTTLE ONLY button and position throttle setting as follows:
a. COLD ENGINE - Move control/throttle lever to full throttle, then return to about 1/4
throttle. In extreme cold it may be necessary to pump lever more than once.
b. WARM ENGINE - Move control/throttle lever to 1/4 throttle position.
c. FLOODED ENGINE - Move control/throttle lever to full throttle. Be prepared to
decrease engine speed to 1000-1500 RPM as soon as engine starts.
IMPORTANT: Do not operate starter motor continuously for more than 30 seconds.
4. Turn ignition key to START. Release key when engine starts and allow switch to return
to ON position.
5. Operate engine for 1 or 2 minutes at fast IDLE (1000-1500 rpm) or until engine temperature
reaches 140-160 degrees F (60-71 degrees C).
6. Inspect the power package for fuel, oil, water and exhaust leaks.
7. To shift into gear, move control handle with a firm, quick motion forward to shift to FORWARD
gear, or backward to shift to REVERSE. After shifting drive unit, advance throttle
to desired setting.
8. Move the remote control handle to NEUTRAL/IDLE and allow the engine to slow to IDLE
speed. If engine has been operated at high speed for a long period of time, allow the
engine to cool at IDLE speed for 3 to 5 minutes.
9. Turn ignition key to the OFF position.
