I have a 1998 3.0 Alpha 1. I pushed air through the cylinders and found air coming out one of the #2 intake so I am guessing it is my head gasket as I have oil in the water. Compression was around 120 for all 4 cylinders. My question is when I am pulling my head the manual that i down loaded only talks about having the #1 cylinder in the top dead center position. Do I need to roll the flywheel to have every cylinder in TDC before I remove all the rockers arms and rods. See SelocMarine Manual steps below that I copied from the online version. I'm guessing they all need to be. If that is the case, any suggestions on how to ensure i do it correctly so I don't mess up the timing. Or is is something I worry about when I put it all back together. Which will be the same question on adjusting the heads
- Open or remove the engine hatch cover and disconnect the negative battery cable. Remove the cylinder head cover as detailed previously.
- Bring the piston in the No. 1 cylinder to TDC. If servicing only one arm, bring the piston in that cylinder to TDC. The No. 1 cylinder on 3.0L engines is the first cylinder at the front of the engine.
- Loosen and remove the rocker arm nuts and lift out the balls. Lift the arm itself off of the mounting stud and pull out the pushrod. It is very important to keep each cylinders component parts together as an assembly. We suggest drilling a set of holes in a 2 X 4 and positioning the pieces in the holes.
