MerkyWater
- May 24, 2018
- 6
Have a 1998 3.0L mercruiser with Alpha One. Last weekend worked on ignition ended up changing slave solenoid. This weekend i have it cranking but i couldnt get her to start. downloaded manual, checked spark and coil. drained fuel from tank. today took carb apart and cleaned it. Well now it will start and run. idles about 900 rpm but will occasionally die if not increased the idle speed. but it will run all day at around 1000-1200rpm.
So, here is the first problem....if you shut it off and restart it right away it starts just fine. if you shut it off and let it set a few min it is very hard to restart and it wont restart without giving it some throttle. in other words it wont restart at just idle speed. So i notice that after it is shut off, if you look down inside the carb, it is steadily dripping gas on both sides. Is it flooding itself out after it is shut off? Is there something not sealing properly inside the carb? float not adjusted properly? when i had it apart i tested the needle and seat and it does shut off when operated manually on the bench.
Also a note, everything inside the carb looks pretty new. so it may have had a kit put in recently, but not sure.
Any suggestions or opinions i would sure appreciate it.
