Mercruiser 262 4.3l V6 TBI Start then stall
maz4477
Hi All,
Firstly may I introduce myself. I am a new first time boater who has bought a "project" boat to get ship shape over the winter ready for some fun off the South coast of the UK next season. I am enjoying finding out about my new intended hobby and the challenge of repairing the boat is part of the enjoyment (some may say I am a glutton for punishment!). Although new to boating, I have worked as a development engineer for 20 years in the automotive field and so I have some knowledge of the systems involved although I recognise that there are differences.
The boat itself is a 2000 Bayliner Capri 2050CZ which it would be fair to say has probably been a bit neglected for the past few years. My wife is cleaning, polishing and renovating generally and it is up to me to get the thing going again. I bought it from a distant friend of a friend as a non-runner and have only sketchy information on what has gone before...
The problem is that the engine will start and run for a few seconds only before dying. It will restart immediately and do exactly the same thing again. If I try to keep it going by giving it some throttle then it can be kept going a little longer by revving it wildly but it will still die out as soon as the revs are dropped. The system is the Mercruiser MEFI3 throttle body injection. The engine has done 207 hours, with 69 of those at <1000rpm. It appears to have plenty of compression as it is hard work for the starter to crank over. I have borrowed a diagnostic tool and there is a Code 33 MAP sensor fault recorded. I can clear this and it will recur on the next run. I have unplugged the ECU connectors and confirmed the power, signal and ground wires to the MAP sensor as OK. I have confirmed that the 5V and ground are present at the MAP sensor connector with the ECU connected. However, if the MAP sensor is disconnected and the ECU is allowed to drop into its rpm based limp home strategy, the engine will start and run continuously without problem! Obviously it will then flag a Code 34 MAP sensor error, but this does not matter. This to me suggests that the fuel delivery side of things is working fine (pump and FPR). Under these circumstances the engine sounds sweet and there is no excessive smoke.
Given the above symptoms I thought that I would take a punt with a new MAP sensor, however, it has not solved the problem (£80 down the drain :-( ) . I have also pulled the MAP sensor out of the manifold, connected a Mityvac vacuum gauge and hand pump to it and monitored the ECU live data (engine off) whilst I vacced the sensor down. The ECU reported vacuum and that on the gauge were pretty well in agreement with each other, which suggests that both the sensor and the ECU input signal conditioning is working fine.
I then connected the vacuum gauge to the inlet manifold with the engine running and found that I was getting a reading of no more than 15" Hg at a fast idle. I wonder if anyone could comment on whether that is acceptable? I did wonder if there was an inlet manifold leak?
There is something else which I think is worth saying. At some time in the past the stock Mercruiser flame arrester has been replaced by a K&N one. However there are no hose connection barbs on the K&N for the hoses removed from the MC one. This has created a few doubts in my mind as to whether the vacuum / venting has been plumbed up right. I could really do with some advice in this respect, particularly from anyone with a similar system. At the moment the hoses are as follows:
- The port side rocker cover vent pipe is just flapping loose.
- The starboard side rocker cover vent pipe is connected to a (vacuum?) spigot in the middle of the aft side of the throttle housing, between the fuel inlet and fuel pressure sensor.
- The diaphragm rupture hose from the reference port of the fuel pressure regulator is connected to the vent port on the side of the distributor. I am pretty sure that this is both wrong and dangerous, but would like your opinions please?
Obviously I need to get any external factors such as venting and vacuum sorted before investigating the engine further and potentially getting the spanners out on it.
Apologies for a long rambling post, particularly as a first one, but I wanted to get all of the information over.
Any ideas anyone?
MAZ4477
Tail_Gunner
The system is fairly simple start with the fuel...measure you fuel pressure under a constant load between the TB and fuel pump...I believe its a constant 30 lbs...If that's normal then take a neon light and watch your injectors firing..they will display a nice conical spray pattern that scales up with rpm
The diaphragm rupture hose from the reference port of the fuel pressure regulator is connected to the vent port on the side of the distributor. I am pretty sure that this is both wrong and dangerous, but would like your opinions please? Do you have pic's that sounds wrong
I have a great mefi diag file PM me I could email to you...IS there a way to attach a 200mb file in here???
Code 33 is voltage high....MAP voltage
code 34 is voltage low......MAP voltage
Sounds like a dead short
http://www.pleasurecraft.com/manuals/L510004.pdf
maz4477
Thanks for the reply Tail-Gunner, also the link to the MEFI3 manual. Very useful. The injectors have a nice conical pattern. As far as the fault codes are concerned, they occur under different circumstances. Code 33 Map voltage high (I.e. not enough vacuum) occurs when I run the engine with everything connected (and it stalls out). The code 34 Map voltage low is what I get if I electrically disconnect the sensor and the engine runs (continuously) using its limp home strategy. I have metered through all of the wiring between the ECU and the Map sensor including the sensor ground and it checks out fine.
Tail_Gunner
The above link is not the file that i have. If you need in depth manuals i will have to email it...about 200mb and covers the about everything including the differnt types of fuel cells and vacum table rates...it is very extensive.. A vacum leak perhaps....not for the faint hearted....One could take starting fluid and spray abit around known leak area's at low idle. If you have a leak that will liven things up a bit
PM me your email address if you need more info
What can you eliminate.. Coolant temp....knock sensor's...MAP....TPS.....that's about it one of those circuts..It could be a tach sensor i have seen those come loose and cut the system off but that's electrical and it seem's you are have fuel starvation?
Below sounds absurd I would post my setup but its volvo with mefi 3 i bit different plumbing.
The aft vacum port should run into the MAP sensor...There should not be any vacum lines on your dist its a t-bolt system or HEI...Is there a vacum line on your MAP?
maz4477
That is a massive file! I know that my email server would bounce that back (50Mb max), so I am not sure how we could get that over other than FTP. Thanks very much for the offer though.
I have toyed with the idea of using propane which seems to be a widely accepted method, but having nearly lost my eyebrows once when it back-popped through the throttle body with the flame arrestor off (whilst checking out the injector spray patterns), I am a bit reluctant! With it running as it is I have my 2kg CO2 fire extinguisher from work at hand when working on it!
Coolant temp is fine. TPS is fine. Not sure that the knock would stop it running, just retard the ignition a bit. Again, if there was a tach sensor problem I don't think that it would run nicely with the MAP sensor disconnected.
Appreciated. Has anyone got the same system as me who could advise on the vent / vacuum routing?
The MAP sensor has a little rubber covered spigot that pushes directly into a port in the inlet manifold, so no pipe involved. I am not sure what marketing name Mercruiser give to my ignition system, but it has a speed sensor pickup in the disi sending signal into the MEFI3 ECU which I assume does the ignition mapping (including knock control) and then drives the coil negative. Nice simple system. I do intend to check the base timing just to be sure that it isn't anything on the ignition side of things, but I doubt it.
For safety for the moment I have removed the diaphragm rupture hose from the distributor vent and left both open to atmosphere.
Thank you for your thoughts.
achris
More fish than mountain goat
To transfer large files without using FTP, just load it up to a file sharing site, like google drive, then post/PM the link....
Maz, do you have the Mercruiser service manual for your engine? It has an extensive fule injection diagnostics section. Something else worth considering is the IAC... That could generate the problem you're having, and when the MAP sensor is disconnected the IAC is not activated... But that would be difficult to see a code 33 being set... Just a thought.
Chris.....
most file sharing sites have around a 100meg limit. for a 200 meg file, you will need FTP site.
Tail_Gunner
https://drive.google.com/file/d/0B3w...it?usp=sharing
Ok well that was easy the first file should give you a good road map to work from..Smiles dunno why I thought the file was 200mb...age is coming my way..to fast.
A leak down test would expose vacuum leak's.
then connected the vacuum gauge to the inlet manifold with the engine running and found that I was getting a reading of no more than.... 15" Hg.... at a fast idle. I wonder if anyone could comment on whether that is acceptable? I did wonder if there was an inlet manifold leak?
14.7 HG is static at sea level....there is no vacuum in the port you took the reading from
achris
14.7 PSI is pressure at sea level... 15" Hg is completely different... 15" vac at fast idle sounds about normal...
maz4477
Thanks for all of the input. Yes, atmospheric pressure here today is around 28"Hg so my 15"Hg shown on the vac gauge equates to 13"Hg absolute. Looking at the vacuum gauge guide link that Tail_Gunner provided it looks borderline OK. I think that I am going to repeat the test before jumping to any conclusions. A leak-down test will only tell me the condition of the cylinder/piston/valves, not anything up front of the inlet valve.
Yes, I do have the main Mercruiser service manual for the engine (#25) and that has got me as far as I have. In particular I have followed through the diagnostic procedure for the MAP sensor error to check the feed, signal and ground connections. It was based on that procedure that I replaced the MAP sensor which has not cured the problem. I will download the MEFI information that Tail-Gunner has kindly provided when I can. Unfortunately too many people have got to the link before me and the Google download quota has been exceeded. I will have to wait until it has quietened down!
Unfortunately I will not be able to get onto the boat until weekend 4/5th October now due to family commitments, but that gives me opportunity to consider the next approach, read the information and get the relevant test equipment around me. Also I can get the batteries charged...
Thanks again.
