ezez
- Jun 3, 2009
- 122
I have acquired a project boat w/ a Mercruiser 260 and Pre-Alpha outdrive. I am troubleshooting power tilt/trim issues.
As an FYI, I have replaced the o-rings and filled with fresh oil in the trim pump.
Mechanically the pump appears to be fine but I believe I have electrical issues. The unit is original and would be an early 1980's pump AFAIK. It has a SINGLE solenoid/relay and I have cleaned all the connections.
Ok so, when I push the bottom button I can get the pump motor to run and the outdrive to go down. When I push the top or middle buttons I get nothing. There is no click, there is no pump motor, there is nothing.
My understanding is that there is a "trim limit switch" that could be the cause or the wiring to it could be corroded and problematic. Any help would be appreciated.
BTW before the "Get a Service Manual Police" come around, I have one ordered and on the way. I am just trying to get head start on things.
