Mercruiser 2006 4.3L Engine Will Not Shut Off
Ortley
Engine will not shut off, Emergency Cut Off Switch does not work. We have replaced the TKS Diode (Bulletin # 2006-04) Twice, Replace the ignition switch (old one tested good), removed alternator, had tested and opened by an alternator repair shop (alternator good). Service centers don't have a glue just say bring in. Any suggestions? We are now thinking it may be something with fuel pump? Thanks for any help - Ortley
achris
More fish than mountain goat
Sounds like you have a short somewhere between main power and ignition power. How do you shut it off?
Bt Doctur
starter solenoid bad, starter solenoid wires/cable touching
alldodge
:welcome: to iboats
Will the engine shut down if the diode is remove?
Have you measured the resistance FWD/REV of the diode, and if so what was it?
If it keeps shorting the diode out, my guess would be something is pulling more current then the diode can take.
Fun Times
Ortley
Thank you all. We stop the boat by pulling the diode which is blown. It usually immediately shuts off. Will check the starter solenoid and for shorts this weekend. I appreciate the guidance. Will be back to you.
