1984 Mercruiser 185
3.8L V6 229 CID
Serial 6691470
Does someone have the manual for this I can take a peek at please? I'm just about to put the heads back on, anyone have any additional tips on the procedure that the manual may not contain? The first last time I did head gaskets I did something wrong and they failed, hoping to not repeat the mistake. Although this time I am paying much more attention to detail and prep work. I used a dye grinder and polished both side to near perfection, but what I haven't done yet is prep the head bolts or threads in the block. Should I use a tap or just a cleaner and blow the holes with compressor?
3.8L V6 229 CID
Serial 6691470
