Hi all, thanks for all of your help thus far and hopefully you can guide me through this one as well.
I have a MerCruiser 170/Alpha 1 with closed cooling, and the previous owner upgraded to a 4" heat exchanger as well. It runs great, but at idle or during low-power use the temperature gauge will read around 110 F (the gauge starts at 100, and the needle just leaves the first mark). I noticed this past weekend after about 20 minutes at 30 MPH that the gauge read about 130 F. I've never seen it higher than this since I bought the boat in April.
Based on what I've read here, this is probably a low reading and has one of three causes. I've got some ideas listed below for troubleshooting; is there anything else I should be thinking about?
1. Engine is actually running cool, gauge and sensor are correct
- Pull thermostat and check in hot water for stuck open wax valve.
- Check and see how how the hoses to/from heat exchanger and engine get (is there any way more scientific than putting a hand on it?).
- Anything else?
2. Engine is running fine but gauge is bad/offset
-Is this gauge a type of device where I can check either voltage or resistance across it for a certain output temperature? If so, any idea what those values should be for a given temp?
3. Engine is running fine and guage is telling the truth but sensor is bad/offset.
- Not even sure where this is on the engine, any ideas on what to look for here?
I know a car wouldn't even be allowed to run too cold and would set a DTC, but I doubt if a boat has that sort of intelligence. I also suspect that my tach is not working properly (I'm well below the specified 4400 - 4800 RPM at WOT on the tach), so perhaps that makes the gauge more likely than the other two? I'll stop typing and let the experts weigh in, thanks for any help you can give.
- Anything else?
