Re: Mercruiser 170 question
Thanks for the response fishinchips and ODDD1. I see the two ports on either side of the outdrive knuckle. Thanks. I would start from trimmed all the down and try to work my way up (my bass boat w/150 merc o/b bites great) but this thing just didn't want to grab. I really don't know much about i/o's but i didn't think they were much different when trying to get up on plane then straight o'b's. Now that you explained about the exhaust, and it seems right, i think it has something to do with the prop. The prop that was origanilly on it when i picked it to was pretty banged up so before i took it out on the water, i put a spare on that i found under the seat. And honestly, this is only my second boat so i really don't know too much about props, but i'm wondering like ODDD1 mentioned that maybe it has something to do with the thrust hub. The only thing i did ODDD1 was take the old banged up prop off and put the spare on. They look like much different props (size & pitch) The original has a # 48 832832 A45 21p stamped on it and the spare has a # 48-58424-21 stamped on it. Both are black. Not sure if this helps. Not sure exactly what fit you're trying to explain put both props fit on the splines perfect and i put the boat in gear and tried to turn each prop to make sure niether was spun. both are fine. Is there suppose to be a washer that goes on the spline before the prop slides on? I didn't look to see if there was one but the front of the original prop looked fine. I would call the guy i'm thinking of buying the boat from but he overdosed on drugs two years ago! What a shame at 35. So i'm buing it from his sister (next of kin) that's had it sitting in her driveway for the last two years and she knows nothing about the boat whatsoever. Thanks again for the help guys. As you can see, i'm pretty much lost on this. Thanks for any info you can provide.<br /><br />- Jersey
