Re: Mercruiser 165 oil in water
So it seems that the water went in that way before and eventually got by the rings. Treat it by getting some oil on the cylinder walls right off. I'd say to remove the spark plugs, ground the coil or if you have a safety lanyard just disconnect it there, squirt some oil in the plug holes, change the milkshake to oil and crank the motor to distribute the oil.
If you want to be really fussy and perfect you can put some water to the lower unit so the impeller doesn't get spun dry, but then you ought to pull a hose off the cooling system inside so it doesn't re water the combustion chambers through the intake crack. With that little cranking it's probably unnecessary though.
BTW good for you if all you need is an intake manifold! Well maybe good for you, is your motor the inline 6, with the combination manifold?
I hear they can run into some money.
