Just one silly question... Why wasn't the drive removed, serviced and stored somewhere warm as part of the winterizing procedure?
depends on if the weep hole is blocked or not i'd think. i've had 2 mc-1 drives. both came with that hole plugged up with sand and crud. i'd guess they both retained water to a degree. however neither cracked. i cleaned out both drive cavities so water will drain. ya do this when your replacing your impeller.Also can the weep hole retain water and crack in the cold?
