billinkansas
- Mar 22, 2008
- 13
I have a Mercruiser 165 inline 6 engine that I bought from someone who started to convert it to a truck motor. The notched timing indicator on the timing chain cover is on the alternator side, the left side viewed from the back of the engine. The normal place is on the other side, from other engines that I've seen. The timing cover appears to be Mercruiser black. I do not have the serial number of the engine, but it would be early 1970's, since it has the red sticker about leaded fuel on the valve cover.
Do I somehow have a reverse rotation engine? I do have a complete semi derelict engine that I could rob parts from if needed.
Thanks in advance!
Thanks in advance!
