Re: MErcruiser 140 water cooling question
I believe he's asking about the location of the drain plugs that are pulled when the engine is winterized.
On that motor there are two. One is a petcock that sticks out of the block on the same side of the motor as the manifold. On mine it's about level with the floor of the boat. The second is in the bottom of the manifold, and it's just a brass plug that threads in. There are quite a few small tapped holes in the bottom of the manifold, so it may be difficult to find the right one. The best way to do this is to run the engine on muffs and watch for drainage out the bottom of the manifold.
Another possibility is that there's a crack in the block. Keep your fingers crossed.
