I have searched several forums and can find no answer. I have a 72' mercruiser 140 3.0 L4 I/O S/N 2770087. As you may already know the intake and exhaust run throught the same manifold. I was wondering if anyone had ever welded up their own sheetmetal intake and exhaust to split the two and reduce intake air charge temps? The placard on the top of the engine states to use only 93 or higher premium leaded fuel. I figure this is to reduce detonation from high intake air temps. Instead of running high octane fuel and lead substitute to reduce engine knock I want to simply reduce air temps. Is their is a two sided cylinder head like modern cars that would swap onto the merc 140 block? Just an idea right now. Maybe it could get me a few more hp from the stock motor. And has anyone ever monitored intake temps at the ports on this motor.
