Mercruiser 140 - questions!
helqud
Hello,
I recently purchased a boat that has a Mercruiser 140. I believe it is a 1987 Sun Runner. It has a hard time starting, and idles really rough. Once I have it in gear and accellerating, things seem to be fine. Here are my questions:
1. Is there a pdf/online repair manual for this motor? (S/N below) If not, can someone reccomend a good one to purchase?
2. I'm thinking the first thing I should do is rebuild the carb. The previous owner hadn't ran the boat for over a year, though he did say he had stabil in the fuel & had it winterized. Is this a good first step? Any reccomendations on where to buy the rebuild kit? Local it is ~$90, not sure if it includes floats (pretty expensive to not include them!).
3. Any hints/tips for this motor?
Motor S/N: 6844079, tag on the carb is 1389-8490
Thanks in advance!
Re: Mercruiser 140 - questions!
Ayuh,...
1),.. This should cover it,...
2),.. I Agree,.... You should also include a Full,+ Complete Tune-up,+ Service...
jerryjerry05
Before you dig into the carb do a GOOD tune up.Points,cap,rotor,plugs.
The carb might just need adjusting.Not rebuilding.Check the gas for water. Jerry
