bobofthedeep
- Aug 29, 2005
- 2
1985 Merc 140....just got it almost free...beware those bearing gifts...<br /><br />Problem is when the ignition switch is turned on, the fuse blows. The fuse is connected from a 12V source under the dash directly to the hot side of the ignition switch. Turning the switch on with a test light shows the light lights dimly for about 3 seconds and blows.<br /><br />Tested the coil, as the ignition wire comes off the switch and goes to the coil. Coil shows .3 Ohms across the primary. If I remove the lead going to the dashboard ignition switch, and hotwire from the battery (with a fuse lol) the fuse blows same way (dim test lamp). I have isolated the stall microswtich out of the circuit, same thing. New points/condenser: same thing. There is a wire going to the starter purple/yellow stripe I think (colorblind) removed that, same thing.<br /><br />Anybody have any thoughts? I wanna go diving.<br /><br />Bob
