Engine: 1984 mercruiser 140
Kind of long, but I didn't want to leave anything out...
First, while running on the lake last weekend, engine started bogging out at high RPM - limped into shore, pulled boat out. looked in valve cover found water mixed w/oil (white muck). Pulled manifold - water gushed out. Plenty of water in cylinders, but no hydrolock. It still ran at idle, but not at higher RPM (>3500). it backfired and lost power at higher RPM. Checked out manifold, found crack or rust-through into ports. Pulled head to check valves, rods, etc - it, looked OK, oiled cylinders, and manually cranked engine - moved pretty good. Changed out oil, replaced manifold. Started engine - runs OK, but still backfiring at high RPM. Found that exhaust shutter was gone, pulled lower unit found shutter blocking exhaust, removed it - tried again, same thing idles great up to about 3500RPM, then backfires. Checked timing - set to 6 deg BTDC - doesn't help. Spark is advancing as RPM rises. The backfiring is pop-pop-pop when I open the throttle slowly at high RPM, or if I bury it at low RPM. Ran compression test - got 150, 140, 145, 145. Replaced points, cap, rotor, wires, plugs. Same symptom. Removed fuel filter, same symptom, put filter back.
Pulled carb, adjusted float level per mercarb spec/bulletin - will try this in the morning.
Other info: brand new cylinder head installed beginning of last year (it rusted through to the outside).
Running out of ideas...
