Last October when I was winterizing I took out the plugs, shot some oil in each cylinder, and turned it over. Water shot out of the #4 cylinder. I didn't have time to work on it then, so I started it up with the #4 plug out, which blew out the water pretty well, then I left them all open for a couple of weeks to dry out, oiled them up, and put it away for the winter.<br />Now it's time to get at the problem. I've been reading the postings, and see head gasket and manifold gasket and manifold crack as likely suspects. <br />Can anyone explain the construction and workings of the Mercruiser exhaust manifold. And what is the "riser"? I know my way around car engines, but this stuff is different.<br />Thanks.
