Mercruiser 120 no spark
Sniper18leafs
Hey everyone new to this boating thing and got myself a project boat it's a 1984 thundercraft, has a 2.5l mercruiser 120, Engine cranks over good but no spark. Going to be changing the points just wondering what else will cause no spark on those engines or if anyone has a wiring diagram so I can make sure everything is correct.
achris
More fish than mountain goat
Hello Sniper18leafs . To get the right engine wiring diagram, we need to know a few things.
1. An engine serial number.
2. If the instrument panel has an ammeter or a volt meter.
3. The colour of the wires on the + of the coil.
4. If it has a fuse on the starter motor terminal.
Chris..........
Ayuh,....... Welcome Aboard,....... If there's power at the coil's (+) tiny terminal, My guess is the points will fix it,.....
Sniper18leafs
Serial number is 6769888
has a volt meter
Wire coming off the + is solid bsolid but doesnt look original
Start motor has a red box looks almost like a relay
I tested the + terminal on the coil and its showing 11.5
79Invader
What color is the wire on the + side of coil? Pop the cap off and inspect points for corrosion or pitting. Heck might as well give them a light sand while you're in there; or just convert to electronic ignition, there is kits online all over.
Bondo is right, if the coil has power like you said, points is likely at fault.
achris
has a volt meter
1984 model. It's a '120R', so this is your wiring diagrams... (I'm going to assume it's a Mando alternator, because Merc used those the most at that point in time. If it's a Delco, let me know...)
Engine
Click image for larger version  Name:	120R wiring.JPG Views:	1 Size:	87.0 KB ID:	10876461
Instrument cluster
Click image for larger version  Name:	instrument.JPG Views:	1 Size:	118.1 KB ID:	10876462
Trim pump (Assuming Dual solenoid system)
Click image for larger version  Name:	3Button-2Sol-trim.png Views:	1 Size:	168.0 KB ID:	10876463
Let me know if any of these aren't right, and if you need anything else.
Chris.......
