sYnOnYx
- Jun 15, 2011
- 41
I have a Mercruiser 120 that I think is in great shape just something simple is wrong.
My first question is does this motor have some sort of choke or cold start mechanism?
Alright here is what it is doing:
It is very hard to start, I have to pump the throttle in neutral pretty good for about 15-25 seconds before it will start it will start very rough. Once it is warmed up it seems like it is ok and Idles at 1,000 RPM just fine. But then it struggles to go higher up in RPM while in neutral and it pops like a misfire. But eventually it will make its way to about 3500 ( I stop it there ) It seems like a misfire or not getting enough fuel issue. Mind you I lean more to the Ignition side cause I tried using starting fluid to help start it and it didn?t help.
So I splashed it this past weekend and while in forward gear it won?t go past 1300rpm?s any movement of the throttle after that it just seems to make a bogging down noise and won?t go any higher.
Where should I start? Does this seem more fuel or ignition related?
