Mercruiser 110 I/O gimbal etc replacement?
ljohnsaw
Sorry for the repost. I got this in Boats and could not get it to delete...<br /><br />In an attempt to get rid of excessive vibration on turning/trimming, I removed my lower and upper outdrive to replace the U-joints. Unfortunatly, they are tight, no play :( . I then shook the bell housing and it has noticable play. Then I looked at the lower gimble and the upper part of the lower bearing is broken off and corroded :eek: . How hard is it to remove the gimble (assuming I can find a replacement) and get a new one aligned up again? Do boat repair places rent alignment tools? I'm sure NAPA doesn't carry them, or do they? Also, I have a crack that looks like a manufacturing defect on the side of the upper unit in the ribbed area (non-stress area). Should the upper unit be replaced, heli-arced or would Liquid Steel do the trick? And, finaly, how the heck do you replace the bellows for the driveshaft and exhaust?<br /><br />Thanks in advance. :rolleyes:
nickster
Re: Mercruiser 110 I/O gimbal etc replacement?
John<br /><br /> Welcome to the board. With all of the problems that you have mentioned in this post you should take your motor to a dealer to do the work. None of these task are very easy and if your not shure of what you are doing you could get very frusterated doing the belows. I recomend a professional doing the job.<br /><br /> Nick
Trent
110......You have an old one! Check this out for the gimble. Yes NAPA does sell aftermarket stuff.<br />Cant see your crack from here but they can be repaired at a prop shop..Most do lower unit welding. web page <br /><br />Anymore questions? Trentcr@hotmail.com<br /><br />Just for your info...That engine went into a 1965 Chevy II Nova.
ljohnsaw
Thanks. Way cool link. Yea, I knew it was a Nova engine. About 5 years ago (right after I got the boat) I had to replace the head and ended up talking with a Nova collector about it. Unfortuatly, I think the entire gimbal (the part mounted to the hull) needs to be replaced because the corrosion is pretty bad on the unit where it broke. I will see if they want to weld it, however. Finding the part is proving to be difficult.<br /><br />John
