Hi All,<br />I started rebuilding my carb on my Mercruiser 110 HP (1964, serial number 1725348 Mercruiser 110). The carb is a rochester 2 jet tag number 7020993. When adjusting my float drop the instructions say to adjust it to 1-29/32(when measureed from the float bowl with gasket in place to the 'seam' on the metal float. The original float was set to 1-21/32. Here is the wierd part, When measuring the total depth of the float bowl, it is only 1-28/32. Given that the float measurement is to the floats seam and that is about halfway on the float. Wouldn't the float literally bottom out before 1-29/32?<br /><br />Sorry to be so detailed, but you know carbs...
