Mercruiser 1.7DTI , throttle problem and timing belt.
nicolajjr
Hi all.
I have 2x Mercruiser 1.7DTI 2006 120HP in our boat.
Is the timing belt "kit" the same for an Opel 1.7DTI?
I have also a problem, the right engine will not charge any Pressure on the Turbo :(
The left engine has a lot of power an rase the RPM instantly. But the right stops at 2000RPM and seems very "dead", it starts so fine and dont use any water or oil. What can it be? in Neutral the engine take with out problem 4600RPM. But does not sound as "brutal" as the left engine.
Thanks.
Nicolaj Denmark
Re: Mercruiser 1.7DTI , throttle problem and timing belt.
Ayuh,... I'd start by changing the fuel Filters...
