I want to get to the bottom of this: I just read the thread from Harold about no forward thrust and he inquired about the throttle and idle cable adjustment. I want the bottom line on this too. If you disconnect the throttle cable at the motor and hand move the linkage on the motor that the throttle cable was attatched to, the only thing that happens is the movement of the gear selector...forward or reverse...there is no movement what-so-ever of the idle lever!! The idle lever on the other hand will retard or advance the distributor, even if you unhook the idle lever cable and move the engine linkage by hand it still moves the distributor...the only way the carb. plates will move is by the movement or rotation of the distributor because the throttle pick-ups are attatched to the distributor...advance the distributor and the carb plates open...moving the throttle linkage at the engine will NOT advance the dist. to allow it to throttle-up, it will only put it in gear!! There has to be a syncronization of these two cables inside the controller. I'm buying an old merController off ebay...just to disassemble it to find out whats inside and how it works! One thing I'm sure of: If you disconnect both cables at the motor they become independent of each other and the corralation between the two is lost.
