Re: merControl Tach Harness
The most drastic and cheapest is to cut off the plug and splice the tach wires to the harness. The best connection is of course the factory harness. Check Twin City Outboards or any other marine recycler/salvage yard in your area. Third, get some female pins at Radio Shack. Attach them to your tach wires, Put heat shrink on each terminal end. Plug each wire into the appropriate pin on the plug from the controller. Secure with tape. Or you can coat the the inside of the plug with a lubricant, attach the wires, and fill the cavity with epoxy. Presto -- a home brew plug is born.
