Hello, I have been working on a project boat and one task that needed to be done was replace the ignition, which required disassembly of the mercontrol, and now I can't get it back together right. Currently it is stuck in reverse from when I start it (supposed to be in nuetral), in forward, and in reverse, and it will throttle up in forward and reverse also. The shifter also moves very stiff and is reluctant to move at all sometimes. I know it worked properly before I took it apart so I know I did something wrong. I also recently took off the lower unit so maybe I connected the shift linkage wrong??? If anybody can guide me it would be great. I want to get this done asap because it is the only thing keeping this boat out of the water and so close to being done with this project.
