i put the tach on 4 and the rpms are only showing about 450rpms out of the water the other settings on the tach show even lower.a freind of mine said i need a tach with a 6p position the sender wire is hooked to a yellow wire on the regulator.would a 6p tach be correct or is something else wrong?
