The cable pulls out about 4 inches when the large retaining nut is removed. It will not pull the other direction (by pulling the end that connects to the motor swing rod). The tube and cable end seem to be bound tight in the motor pivot. I have heard of the complete steering kit. How do I remove the stuck end from the motor pivot? If it requires heat, I will have to get someone else to do it. Is there a set screw that I am not finding that holds the tube in place? Thanks!<br />I am new here and just got the boat as is but all else seems fine. I did a search but did not find this covered.
