I picked-up my '69 100 HP six saturday. After being reassured that this motor ran in the summer(lower unit was off for impeller change)I've discovered that the stator is putting out about 20 volts while cranking.Is this enough voltage to run?? (Seloc manual on order,my manual for my 500 hp four isn't clear on stator output.Take to friendly Mercury Dealer it tells me...)Second question is I've got number 3 cylinder with 5 pounds of compression and number 4 with 70 pounds.the rest of the cylinders are close to 100 pounds.Can I expect more compression while saturating the naughty cylinders with carb cleaner and let 'em soak??? Am I floggin' a dead mule or should I throw some money and time at it?? It sure looks mean and sexy on the back of The Whaler, I need some advice here.Thanks.
