Re: Merc V6 135hp 1993
Many thanks for reply. I found out the same way as you as have just fitted a Furuno e/s which physically alarms at 16.5volts. There are 2 voltage regs on my engine and by disconnecting one and running it with an avo on the battery the fault was traced to the upper one. Voltage when just the bottom one in circuit was steady 13.8V. Have purchased new unit (£150) but was keen to test the old one even though it is a sealed unit.
