the book states to read tdc with a dial indicator then back counterclockwise past .464 a quater turn then back to the .464 mark or on the flywheel then reset the pointer ? is the only thing you use the dial indicator for is finding the tdc ? if i use the dial and go .464 the .464 does not line up any close to the pointer. or can i do this find the tdc then line up the 0 mark on the flywheel ? the book jumps from reading the dial to reading the flywheel decal inthe same sentance . im lost can any one help ?
