Re: Merc Sportjet 90
He speaks the truth , test the stator , the newest part number is 835075a21 , there are a series of tests to run , first disconnect the kill wire from the switch box , kill wire should be black with yellow stripe . If spark returns then post up and we can go down that diagnostic tree . It probably will not , You need to remove the flywheel on top of the motor USING A PROPER PULLER (they are available at Auto Zone for like 15 bucks) and post what color the stator is . Also head out ot LOWES and get a multi meter cause you are going to have to take some readings to find what is bad ... Get this done and post up we can go from there ... Bob
PS send me an e-mail with your e-mail addy and I can send you some tests to do
