Merc Risers 87114-C
Hallo
Had a problem before with water getting on top of cylinders. It was suggested that i check the manifolds and risers for cracks.(no water in oil had to remove plugs drain water for it to start). What i found was a small hole on both risers underneath where the boot slips on to the riser at bottom
almost in the same place as the other. Could this be why i'm getting water on the cylinders?
