Merc Question
evinrude
working on a 1996 40 merc boat ued to go great. it has fished all it life at about 1000-2000 rpm top plug changed every year well now the boat has no top endwhen you open it up it gets to about 4,000 rpm that it it run fine other the that almost like exhaust is cloged or something any idea we be much appreciated.
evinrude
Re: Merc Question
i meant to say 1000-2000 rpms tops. plugs changed every year.
roscoe
Re: Merc Question
Yes, decarb. Clean out the crud.<br /><br />Your intent is REMOVE the existing carbon buildup from the cylinders, heads, and rings, a spray decarb solvent product is needed. Buy at least 2 cans of decarb. Some people use one can per cylinder.<br /><br />Run engine at fast idle, with engine running, slowly spray liberal amount into each carb,<br />spray some more, spray a larger amount into carbs until engine chokes out and stops,<br />remove spark plugs and spray decarb liberally into each cylinder, install the spark plugs, let it soak for 1 to 10 hours. <br />Start the engine and run at medium throttle, or if at the lake, run it at full throttle. It won't hurt to spray some more through the carbs. Run it for atleast 10 minutes to flush the crud out of your engine. Now remove and clean, or replace the spark plugs. <br /><br />Next I would do a carb rebuild.
