merc prop
tbjtib
Hi,I have a 81 inline six 90 hp merc. The prop is 13x19 The rpms tops out at 5400,the book says 5000 should be max. Would it be better to up the pitch or stay off the thottle a little? Thanks,Timb
rickdb1boat
Re: merc prop
What size and type boat are you running? What is the main use of the boat?(Sking, fishing, Ect) You are probably close with the prop you have, but it wouldn't hurt to stay out of it a bit, especially avoiding long periods using full throttle. You will sacrifice hole shot if you go up in pitch, but then again you may get better top end speed and stay within the recommended RPM range.
