dave buckner
- May 26, 2002
- 41
new boater just finished rebuilding upper outdrive on '74 galaxy with merc 165 i/0. boat performed great other than one new quirk: boat shifts into drive at idle fine, but as more throttle is applied motor dies most of the time. after several tries, she will accept throttle and drive normally. reverse gear acts norm0to WOT is no prob in reverse. there seems to be no major problem with either motor or outdrive( as boat cruised all day after getting past idle) i have checked shift and throttle cables, and adjustment seems fine. adjusting shift cable to either extreme did not have an effect on problem. my clymer manual only helps to an extent as it covers so **** many models and doesnt give any info to identify my setup. i am thinking there is a clutch in the lower unit. i dont see why clutch adjustment would be affected by upper rebuild. would a shot cluth give me these symtoms all of a sudden? is there something else i may be overlooking? by the way i drained gear oil and it looks new, no water, gear parts , etc. <br /> this forum has been invaluable to me as a new boater and DIY'er mechanic. any tips are always appreciated. THANKS!!!
