Captain Curt
- Aug 2, 2012
- 6
Our little boat had been trouble free the past few years after the switchbox, stator and trigger were replaced. This fall we were coming home at a slow idle , tried to throttle the engine bogged down and stalled. Fortunitly the motor started and we limped about a 1/4 mile home. Now the engine barely runs when started. With the covers off the black / white trigger wire got hot and the insulation is melted about two inches from switchbox terminal towards the trigger. I measured resistance on the rectifier (not in circuit) and is open. I used an automotive timing light , clamped over each plug wire and all three plugs are getting pulses . The motor has a modified stator as only the blue wire switchbox terminal has a connection, with a blue wire and a wire from the stator resistor pack (the red wire switchbox terminal has no wire connected) . I took readings on the rectifier 10K forward 100K reversed on the yellow to red wires. The yelow to yellow wires read very near 0 ohms. All three coils read about 850 ohms . The trigger black/white to purple, white and brown all read 1200 ohms. a I am assuming this is a red stator with a resistor pack. I need to get a DVA at some point . Any ideas?
