Merc Lower unit leak driving me bananas
G
Guest
Guest
Hey all, I am confused about this color of the oil. i mixed a little bit of water and oil and colors matched a little. I
pressure tested my LU in tub and it is holding well at 40 psi. Looks like a get a bubble every 6-8 seconds from #20 and #26 but like i said pressure is still holding. I am using Pennzoil marine gear lube. Should i use something else or is this normal??WP_20140415_17_53_12_Pro.jpgWP_20140415_17_51_03_Pro.jpgWP_20140415_17_51_26_Pro.jpgWP_20140415_17_51_52_Pro.jpgpic.JPG
Faztbullet
Re: Merc Lower unit leak driving me bananas
You need to pressure test it at 15psi and vaccum test it at 15psi.
GA_Boater
Pour it in a clear container. If it has water, it will float to the bottom. Lower unit gear oil and water do not stay mixed.
G
Guest
Guest
i poured it into a clear ziplock and did not see any separation in liquid
bruceb58
You are pressure testing it without oil in it right?
Faztbullet
If its cheap 80/90 auto oil it will areate and look like that....
G
Guest
Guest
went out and purchased Mercury Gear lube
Mi duckdown
weimed. Good move on the merc lube. make sure that there is NO OLD VENT/FILL gasket material stuck to the lower end Hole housing. Use a pick or small screwdriver to clean. Use New gasket/washer when you refill lower. Run for awhile and check lower end for water again. Seen this a lot with stuck washer on housing..02
G
Guest
Guest
That's another thing.
Do you always replace the gaskets on all your drain/fill/vent plugs every oil change?
I installed a new impeller kit
I was advised to run it in the water for a full day then check again. Soon as i do i will report results. Thank you everyone
