All,
I just had my the upper and lower units professionally resealed. I took it out over the weekend and ran it normally. When I started I had lube at the fill line. However, I checked it one morning and it was about 15% less than when I started. I then ran it for a few minutes and ran it in gear at low idle and the fluid level was above the fill line. Now that I have stopped and trailered it back to home the fluid level is about 15% less full than when I started.
Is this normal? Trapped air? I think it is leaking.
The reseal was preventative maintenance, but I was losing a little fluid and knew that the issue would get worse. Now the apparent loss is more than when I started.
