This may be the wrong forum subgroup, but I have a 1982 Sunrunner 245 with a merc 5.7. It has twin saddle fuel tanks and orginally had an electric tank switch solenoid that said " not for marine use ". I replaced it with a manual 3 way valve so I can select either tank or turn off. It is mounted on the bulkhead in front of the engine., down in the compartment
My concern is, that in the event of an engine compartment fire, I may be unable to shut off the fuel supply ( before I jump overboard ), after opening
the covers.
Does someone make a simple on / off 12v valve that is approved for marine use and how would I install it, if so?
the covers.
