Idle set too low?? What is the lowest rpm's that it will continue to run at? If when you backoff on throttle from there does the rpm go further down?<br /><br />Craig
Check the compression. Should be within 15% of each other. If that's ok. Try adjusting idle mixture. If that doesn't help you MIGHT need to remove and clean the carb idle circuits.
