merc alpha one drive broken help
bolo78910
hello guys, i am back again , was heading out to the fishing ground doing about 20 knots when clunk i lost power engine runs but not going in drive or reverse.
is it my coupler , drive shaft help please the best part of the fishing season is here. engine rev but prop is not movine. merc 5.7 alphaone drive 1.5
Re: merc alpha one drive broken help
Ayuh,... Have you Looked at it Anywhere, Any how,..?? What's movin', n what Ain't,..??
Are there Chunks in the oil,..?? Have ya Looked,..??
There's No Answers without background Info....
At this point I can tell ya 1 thing for Sure,.... I'm absolutely certain, it's Broken....
Keep an eye on the temp gauge while it's runnin, and your testin.
If it's the coupler, the impeller in the drive won't be spinnin.
If it's the driveshaft at the top of the lower unit in the drive that is sheared off, the impeller won't be spinnin.
dingdongs
may be no teeth on gears or verticle shaft splines may have sheared.have a look under top cap as it only takes 2 mins to remove.engine not running of course.if u select either gear rotating prop should c some results.
bolo78910
thanks guys i did not do any testing as yet, boat is still in the water .
ok i did a few search and found some info, with the engine running look to see if the shaft behind engine is turning that should rule out the coupler ???
with the engine off push the shifter wot in drive spin the prop by hand ccw it should engage ???? any more info to take with me guys.
thanks
dubs283
yes
if the shaft is turning, the coupler is okay
with the boat out of the water and engine OFF, put the drive in FWD gear and rotate prop counterclockwise, if the prop spins see if the propshaft spins too, if not - spun prop hub
if the propshaft spins with the prop, pull the top cap on the drive and see if the gears are shredded
bolo78910
ok guys update update, boat is out the water now , i push the shifter to wot, then turn prop by hand, gess what prop turn but the shaft dosent i could calerly see where the hub is spinning free. next install a new prop with new hub turn ccw again this time it dosent slip, i then went to the damper and make a mark, go back and turn the prop real hard take a lot of strenth it turn the damper and the flywheel so that rulu out a fail coupler. i pull the coil wire turn the engine ove with the keys the coupler spins so coupler is good. what is happen now is it is not going in drive or reverse, i put a muff on and start it up no drive or reverse. when push the shifter to wot the little ball on the shift intrupter does nothing it just sit there in the valley. could it be the shift cable slip of the drive .
what could cause it to not going in gears. ???? is the drive shot?? is it possible that on that day the drive came up with two problem at once . spun prop and something else???
thank guys i think we are close in solving this.
Don S
Disconnect the lower shift cable at the engine. The cable that goes from the engine to the outdrive. Now, start the engine on muffs and at idle see if you can shift gears by pushing and pulling the lower shift cable itself.
Have you changed the gear lube yet and looked at the gear lube and magnet on the drain plug?
bolo78910
thanks don s no i did not change the lube this season, i did last season.
i will do that this week , and i will also do what you say about disconnect the shift cable, sopose it shift then don what problem are we looking at?? thanks
bolo78910
after sitting here trying to solve this puzzle, this is what i came up with, with the engine off it goes in gear that is why the prop lock up, right?? but with the engine running it does nothing. aaagg wow puzzle.
bolo78910
ok went back runs the engine on the muff, disconnect the shift cable, pull on push it but still did no go in gear. your thought guys. is it time for a new drive, foget to mention i drain the fluid but cant find any partacels in the oil or the magnet. also pull the top off and dont see where the gears damage.
that it guys
If it were me, I'd pull the whole drive, and then separate the upper and lower half.
My guess is the splined driveshaft on the lower half has sheared off at the oring just below the splines.
Here's a video on separating the upper and lower half of the drive.
http://www.youtube.com/user/TcElectronicsMarine#p/u/7/kfpasFN_g8w
Here's a pic of just the lower half so you can see the driveshaft on the lower.
bolo78910
thanks eric so ru saying if that the case, it is time for a new drive.
i call the yard mechanic earlyer and told him to give the cable a try i hope he will get back to me tonight, maybe i was doing wrong i hope.
"IF" that is the case it's time for a new lower half, or have that one fixed, which usually costs more than a new aftermarket lower.
You can buy the drive as a complete unit, upper half or just lower half. If the upper is in good shape, which you said you opened the top cover and the gears looked good?
But I wouldn't just go buy a new anything without confirming what is actually broken.
bolo78910
got a call just now from the mechanic he said he used the cable to put it in drive and it works, what now guys.
Ok so, lets think about this... Shifting the drive by hand will engage forward and reverse, engine will not transfer power to the prop.
You already opened the top cover and the gears looked good and the shaft IS turning behind the engine...
bolo78910
correct on that, base on what the the mechanic just told me.
imraan47
I have had the similar problem and it was my coupler.
i also put in a new gimble
dingdongs
as stated previously if its going in gear turn prop and see if the gears r rotating as i believe you have lost the splines off the verticle shaft.look in cap whilst doing this.more than likely its time to drop lower off as guessing is getting us nowhere.
:rolleyes: :rolleyes: ;);)
